Salta al contenuto principale
Dell Inspiron 3552 Hard Drive Replacement Part 1
Cosa ti serve
  1. Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the battery: passo 1, immagine 1 di 1
    • Close the display and turn the computer over
    • Slide the battery-release latch to the unlocked position
    • Lift the battery at an angle and remove the battery from the battery bay
  2. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing optical drive: passo 2, immagine 1 di 1
    • Remove the screw that secures the optical-drive assembly to the base cover.
    • Using a plastic scribe, push the optical-drive assembly out of the optical-drive bay.
    • Pull the optical-drive assembly out of the optical-drive bay.
  3. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing keyboard: passo 3, immagine 1 di 2 Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing keyboard: passo 3, immagine 2 di 2
    • Turn on the computer over and open the display
    • Using a plastic scribe, gently release the tabs that secure the keyboard to the palm-rest assembly
    • Slide the keyboard up to release it from the slots on the palm-rest assembly.
    • Carefully turn the keyboard over and place it on the palm-rest assembly
  4. Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: passo 4, immagine 1 di 3 Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: passo 4, immagine 2 di 3 Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: passo 4, immagine 3 di 3
    • Open the display and remove the screws that secure the palm-rest assembly to the base cover from its connector on the system board
    • Open the latch and disconnect the optical-drive cable from its connector on the system board
    • Close the display and turn the computer over.
    • Remove the screws that secure the base cover to the palm-rest assembly
    • Using your fingertips, gently pry the base cover off the palm-rest assembly
  5. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing the base part 2: passo 5, immagine 1 di 1
    • Release the optical-drive interposer from the tabs on the base cover.
Conclusione
Jordon Dozier
Membro da: 02/10/21
1.663 Reputazione
12 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
43 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 950
