Salta al contenuto principale
Dell Inspiron 3552 Hard Drive Replacement part 2
Cosa ti serve
  1. Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: passo 1, immagine 1 di 3 Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: passo 1, immagine 2 di 3 Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: passo 1, immagine 3 di 3
    • Remove the screws that secure the hard-drive assembly to the palm-rest assembly
    • Open the latch and disconnect the hard-drive cable from the system board
    • Lift the hard-drive assembly off the palm-rest assembly
    • Disconnect the interposer from the hard-drive assembly.
    • Remove the screws that secure the hard-drive bracket to the hard drive and lift it off the hard drive.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive
    • Connect the interposer to the hard-drive assembly
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly
    • Replace the screws that secure the hard-drive assembly to the palm-rest assembly.
    • Slide the hard-drive cable into the system-board connector and close the latch to secure the cable.
Conclusione
Altre 2 persone hanno completato questa guida.
Jordon Dozier
Membro da: 02/10/21
1.663 Reputazione
12 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
43 Membri
1.985 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 373
