Salta al contenuto principale
Dell Inspiron 1525 Heat Sink Replacement
Cosa ti serve
  1. Dell Inspiron 1525 Heat Sink Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Heat Sink Replacement: passo 2, immagine 1 di 2 Dell Inspiron 1525 Heat Sink Replacement: passo 2, immagine 2 di 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: passo 3, immagine 1 di 2 Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: passo 3, immagine 2 di 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: passo 4, immagine 1 di 3 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: passo 4, immagine 2 di 3 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: passo 4, immagine 3 di 3
    • Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
    • These screws are attached to the heat sink assembly.
    • Gently lift the heat sink from side indicated in the picture.
    • The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
    • Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
Conclusione
Altre 5 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 7,849
