Salta al contenuto principale
Dell Inspiron 15-5565 Wireless Card Replacement
Cosa ti serve
  1. Dell Inspiron 15-5565 Wireless Card Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Wireless Card Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15-5565 Wireless Card Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15-5565 Wireless Card Replacement: passo 2, immagine 3 di 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Wireless Card Replacement, Back Cover: passo 3, immagine 1 di 2 Dell Inspiron 15-5565 Wireless Card Replacement, Back Cover: passo 3, immagine 2 di 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Wireless Card Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-5565 Wireless Card Replacement: passo 4, immagine 2 di 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Wireless Card Replacement, Wireless Card: passo 5, immagine 1 di 2 Dell Inspiron 15-5565 Wireless Card Replacement, Wireless Card: passo 5, immagine 2 di 2
    • Remove the single screw securing the wireless card bracket using a Phillips #00 screwdriver.
    • Slide the bracket to remove it.
    • Disconnect the two cables from the wireless card.
  6. Dell Inspiron 15-5565 Wireless Card Replacement: passo 6, immagine 1 di 1
    • Slide out the wireless card to remove it from its slot.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 106
