Salta al contenuto principale
Dell Inspiron 15 7579 Speakers Replacement
Cosa ti serve
  1. Dell Inspiron 15 7579 Speakers Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Speakers Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15 7579 Speakers Replacement: passo 2, immagine 2 di 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Speakers Replacement, Battery: passo 3, immagine 1 di 2 Dell Inspiron 15 7579 Speakers Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Speakers Replacement: passo 4, immagine 1 di 1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
  5. Dell Inspiron 15 7579 Speakers Replacement, Speakers: passo 5, immagine 1 di 2 Dell Inspiron 15 7579 Speakers Replacement, Speakers: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • After battery is removed, locate the left and right speakers.
    • On the right speaker assembly, remove the pin connector using the tweezers.
  6. Dell Inspiron 15 7579 Speakers Replacement: passo 6, immagine 1 di 2 Dell Inspiron 15 7579 Speakers Replacement: passo 6, immagine 2 di 2
    • Use the metal spudger to pry off the right speaker assembly.
  7. Dell Inspiron 15 7579 Speakers Replacement: passo 7, immagine 1 di 1
    • Use a metal spudger to pry off left speaker assembly.
  8. Dell Inspiron 15 7579 Speakers Replacement: passo 8, immagine 1 di 2 Dell Inspiron 15 7579 Speakers Replacement: passo 8, immagine 2 di 2
    • Un-thread the wire by removing them from under the plastic clamps. No tools are required for this step. Repeat for both sides.
  9. Dell Inspiron 15 7579 Speakers Replacement: passo 9, immagine 1 di 2 Dell Inspiron 15 7579 Speakers Replacement: passo 9, immagine 2 di 2
    • Pull the adhesive cable away from the metal backing and push the right speaker assembly under it.
    • Remove the Velcro holding the speaker wire and remove the speakers from the device.
Conclusione
Cal Poly, Team S24-G9, Maness Spring 2018 Membro di Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,222
