Salta al contenuto principale
Dell Inspiron 14-5415 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 14-5415 Hard Drive Replacement, Back Cover: passo 1, immagine 1 di 1
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Remove the screw from the hard drive using a Phillips #00 screwdriver.
  4. Dell Inspiron 14-5415 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Carefully pull the hard drive out of its position.
    • Be sure to handle the hard drive with care. It should not need to be pulled hard to remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 232
