Salta al contenuto principale
Dell DJ Screen Replacement
Cosa ti serve
  1. Dell DJ Screen Replacement, Screen: passo 1, immagine 1 di 2 Dell DJ Screen Replacement, Screen: passo 1, immagine 2 di 2
    • First, disassemble the device, taking off the top and bottom panels. See the disassembly guide for further directions.
  2. Dell DJ Screen Replacement: passo 2, immagine 1 di 3 Dell DJ Screen Replacement: passo 2, immagine 2 di 3 Dell DJ Screen Replacement: passo 2, immagine 3 di 3
    • Slide the internal components out of the case.
    • Clean all areas of the device, making sure to clear all crevices of dirt and grime. Appropriate materials include: a water dampened cotton cloth, microfiber cloth, cotton swabs, and disposable wipes made for electronic devices.
    • If the device has a lot of dirt on the internal components, this may be the cause of the screen malfunction. Reassemble device at this point to see if it has fixed the problem.
  3. Dell DJ Screen Replacement: passo 3, immagine 1 di 2 Dell DJ Screen Replacement: passo 3, immagine 2 di 2
    • Disconnect side clips of screen to detach the base of it from the main circuit board, using the metal spudger.
  4. Dell DJ Screen Replacement: passo 4, immagine 1 di 3 Dell DJ Screen Replacement: passo 4, immagine 2 di 3 Dell DJ Screen Replacement: passo 4, immagine 3 di 3
    • Carefully pull the screen up so that it is only attached at the top side.
    • Pull gently to fully detach screen from device.
  5. Dell DJ Screen Replacement: passo 5, immagine 1 di 2 Dell DJ Screen Replacement: passo 5, immagine 2 di 2
    • To replace, purchase a new screen and locate the small silver bar located on the motherboard.
    • Insert the end of the new screen into the opening of the silver bar, securing it in there to hold your new screen.
    • After the device is assembled, power the device on. The issue should be repaired.
    • If the device screen is still defective, an issue with the motherboard or a greater malfunction could be the cause.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 269
