Salta al contenuto principale
Dell Chromebook 5190 I/O board Replacement
Cosa ti serve
  1. Dell Chromebook 5190 I/O board Replacement, Battery: passo 1, immagine 1 di 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 I/O board Replacement: passo 2, immagine 1 di 3 Dell Chromebook 5190 I/O board Replacement: passo 2, immagine 2 di 3 Dell Chromebook 5190 I/O board Replacement: passo 2, immagine 3 di 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 I/O board Replacement: passo 3, immagine 1 di 2 Dell Chromebook 5190 I/O board Replacement: passo 3, immagine 2 di 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 I/O board Replacement: passo 4, immagine 1 di 2 Dell Chromebook 5190 I/O board Replacement: passo 4, immagine 2 di 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 I/O board Replacement: passo 5, immagine 1 di 2 Dell Chromebook 5190 I/O board Replacement: passo 5, immagine 2 di 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 I/O board Replacement: passo 6, immagine 1 di 3 Dell Chromebook 5190 I/O board Replacement: passo 6, immagine 2 di 3 Dell Chromebook 5190 I/O board Replacement: passo 6, immagine 3 di 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 I/O board Replacement, I/O board: passo 7, immagine 1 di 2 Dell Chromebook 5190 I/O board Replacement, I/O board: passo 7, immagine 2 di 2
    • Disconnect the first purple I/O cable by lifting upwards and pulling away from the I/O connector.
  8. Dell Chromebook 5190 I/O board Replacement: passo 8, immagine 1 di 2 Dell Chromebook 5190 I/O board Replacement: passo 8, immagine 2 di 2
    • Disconnect the second purple I/O cable by lifting upwards and pulling away from the I/O connector.
  9. Dell Chromebook 5190 I/O board Replacement: passo 9, immagine 1 di 3 Dell Chromebook 5190 I/O board Replacement: passo 9, immagine 2 di 3 Dell Chromebook 5190 I/O board Replacement: passo 9, immagine 3 di 3
    • Unscrew the two (M2x4) screws on the I/O bracket.
    • Lift off the I/O bracket.
  10. Dell Chromebook 5190 I/O board Replacement: passo 10, immagine 1 di 2 Dell Chromebook 5190 I/O board Replacement: passo 10, immagine 2 di 2
    • Unscrew the three (M2x4) screws on the I/O board.
    • Dismount the I/O board.
Conclusione
Denise Cano
Membro da: 02/10/22
617 Reputazione
4 Guide realizzate
Gateway, Team 1-3, Pee Spring 2022 Membro di Gateway, Team 1-3, Pee Spring 2022
GCC-PEE-S22S1G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 221
