Salta al contenuto principale
DeWalt DC970 Motor Replacement
Cosa ti serve
  1. DeWalt DC970 Motor Replacement, Battery: passo 1, immagine 1 di 1
    • Compress the buttons on either side of the battery and lift the drill away from battery.
  2. DeWalt DC970 Motor Replacement: passo 2, immagine 1 di 1
    • Remove battery from drill.
  3. DeWalt DC970 Motor Replacement, Drill Assembly: passo 3, immagine 1 di 2 DeWalt DC970 Motor Replacement, Drill Assembly: passo 3, immagine 2 di 2
    • Remove the eight 16 mm, Torx Security #15 screws.
  4. DeWalt DC970 Motor Replacement: passo 4, immagine 1 di 1
    • Lay the drill on its side and gently lift the top half off it.
  5. DeWalt DC970 Motor Replacement, Motor: passo 5, immagine 1 di 1
    • Lift drill mechanism out of the shell.
    • Desolder the red and black wires from the motor.
    • Learn more about soldering here.
  6. DeWalt DC970 Motor Replacement: passo 6, immagine 1 di 1
    • Slightly twist and pull motor away from the clutch.
  7. DeWalt DC970 Motor Replacement: passo 7, immagine 1 di 1
    • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
Conclusione
Altre 2 persone hanno completato questa guida.
3 Commenti
Unplug the wires from the trigger switch....don't unsolder.
New motor comes with wires.
allen.anderson1 - Replica
Thanks for the heads up on the wires
Daniel Randall - Replica
Is there a fix to replace brushes?
pmac086 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 31
Tutti i Tempi: 6,505
