Salta al contenuto principale
DROCON Ninja Motor Replacement
Cosa ti serve
  1. DROCON Ninja Motor Replacement, Battery: passo 1, immagine 1 di 3 DROCON Ninja Motor Replacement, Battery: passo 1, immagine 2 di 3 DROCON Ninja Motor Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Motor Replacement, Casing: passo 2, immagine 1 di 3 DROCON Ninja Motor Replacement, Casing: passo 2, immagine 2 di 3 DROCON Ninja Motor Replacement, Casing: passo 2, immagine 3 di 3
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Motor Replacement: passo 3, immagine 1 di 2 DROCON Ninja Motor Replacement: passo 3, immagine 2 di 2
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Motor Replacement: passo 4, immagine 1 di 3 DROCON Ninja Motor Replacement: passo 4, immagine 2 di 3 DROCON Ninja Motor Replacement: passo 4, immagine 3 di 3
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
  5. DROCON Ninja Motor Replacement, Motor: passo 5, immagine 1 di 2 DROCON Ninja Motor Replacement, Motor: passo 5, immagine 2 di 2
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
  6. DROCON Ninja Motor Replacement: passo 6, immagine 1 di 3 DROCON Ninja Motor Replacement: passo 6, immagine 2 di 3 DROCON Ninja Motor Replacement: passo 6, immagine 3 di 3
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
  7. DROCON Ninja Motor Replacement: passo 7, immagine 1 di 3 DROCON Ninja Motor Replacement: passo 7, immagine 2 di 3 DROCON Ninja Motor Replacement: passo 7, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the two 5mm screws connecting the motor arm to the drone's body.
    • Use your fingers to gently pull the white plastic disc out of the motor arm.
  8. DROCON Ninja Motor Replacement: passo 8, immagine 1 di 3 DROCON Ninja Motor Replacement: passo 8, immagine 2 di 3 DROCON Ninja Motor Replacement: passo 8, immagine 3 di 3
    • Grasp the motor arm and pull up and away from the drone's body.
  9. DROCON Ninja Motor Replacement: passo 9, immagine 1 di 3 DROCON Ninja Motor Replacement: passo 9, immagine 2 di 3 DROCON Ninja Motor Replacement: passo 9, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the three 4mm screws on the plate of the motor arm.
    • Using your fingers, pull apart the top and bottom pieces of the casing.
  10. DROCON Ninja Motor Replacement: passo 10, immagine 1 di 3 DROCON Ninja Motor Replacement: passo 10, immagine 2 di 3 DROCON Ninja Motor Replacement: passo 10, immagine 3 di 3
    • Use the opening tool to remove the small circuit board from the motor arm.
  11. DROCON Ninja Motor Replacement: passo 11, immagine 1 di 3 DROCON Ninja Motor Replacement: passo 11, immagine 2 di 3 DROCON Ninja Motor Replacement: passo 11, immagine 3 di 3
    • Use a pair of pliers to remove the motor by pulling up and away from the propeller arm.
Conclusione
Altre 2 persone hanno completato questa guida.
1Commento della guida
I’ve got the motor out. Thank you! Now to find a suitable replacement. Do you know the specs of the motor or a source for a working one?
Tinkerer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 858
