Salta al contenuto principale
DR.J Professional HI-04 Lens Replacement
Cosa ti serve
  1. DR.J Professional HI-04 Lens Replacement, Lens: passo 1, immagine 1 di 3 DR.J Professional HI-04 Lens Replacement, Lens: passo 1, immagine 2 di 3 DR.J Professional HI-04 Lens Replacement, Lens: passo 1, immagine 3 di 3
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Lens Replacement: passo 2, immagine 1 di 3 DR.J Professional HI-04 Lens Replacement: passo 2, immagine 2 di 3 DR.J Professional HI-04 Lens Replacement: passo 2, immagine 3 di 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Lens Replacement: passo 3, immagine 1 di 2 DR.J Professional HI-04 Lens Replacement: passo 3, immagine 2 di 2
    • Gently lift the black flap off from the base of the lens.
  4. DR.J Professional HI-04 Lens Replacement: passo 4, immagine 1 di 2 DR.J Professional HI-04 Lens Replacement: passo 4, immagine 2 di 2
    • Remove the lens from the projector.
    • The lens is no longer secured but might still be tightly in place. Be gentle while removing it.
  5. DR.J Professional HI-04 Lens Replacement: passo 5, immagine 1 di 2 DR.J Professional HI-04 Lens Replacement: passo 5, immagine 2 di 2
    • Unscrew the cover of the lens.
Conclusione
Kory Lajoie
Membro da: 11/01/23
127 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Membro di UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 48
Tutti i Tempi: 313
