Salta al contenuto principale
D-Link DIR-890L Power Adapter Port Replacement
Cosa ti serve
  1. D-Link DIR-890L Power Adapter Port Replacement, Case: passo 1, immagine 1 di 3 D-Link DIR-890L Power Adapter Port Replacement, Case: passo 1, immagine 2 di 3 D-Link DIR-890L Power Adapter Port Replacement, Case: passo 1, immagine 3 di 3
    • Peel off the four rubber rectangular feet with your fingers.
    • The feet may be hard to remove. Apply additional force if necessary.
  2. D-Link DIR-890L Power Adapter Port Replacement: passo 2, immagine 1 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 2, immagine 2 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 2, immagine 3 di 3
    • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
  3. D-Link DIR-890L Power Adapter Port Replacement: passo 3, immagine 1 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 3, immagine 2 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 3, immagine 3 di 3
    • Wedge the opening tool between the red top panel and the gray bottom panel.
    • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
  4. D-Link DIR-890L Power Adapter Port Replacement, Motherboard: passo 4, immagine 1 di 1
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  5. D-Link DIR-890L Power Adapter Port Replacement: passo 5, immagine 1 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 5, immagine 2 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Spudger
  6. D-Link DIR-890L Power Adapter Port Replacement: passo 6, immagine 1 di 2 D-Link DIR-890L Power Adapter Port Replacement: passo 6, immagine 2 di 2
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  7. D-Link DIR-890L Power Adapter Port Replacement: passo 7, immagine 1 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 7, immagine 2 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 7, immagine 3 di 3
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  8. D-Link DIR-890L Power Adapter Port Replacement: passo 8, immagine 1 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 8, immagine 2 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 8, immagine 3 di 3
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  9. D-Link DIR-890L Power Adapter Port Replacement: passo 9, immagine 1 di 2 D-Link DIR-890L Power Adapter Port Replacement: passo 9, immagine 2 di 2
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
  10. D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: passo 10, immagine 1 di 3 D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: passo 10, immagine 2 di 3 D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: passo 10, immagine 3 di 3
    • Locate the power adapter port at the top left of the motherboard.
    • Flip the motherboard over.
    • Locate the 3 solder joints that connect the power adapter port to the motherboard.
  11. D-Link DIR-890L Power Adapter Port Replacement: passo 11, immagine 1 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 11, immagine 2 di 3 D-Link DIR-890L Power Adapter Port Replacement: passo 11, immagine 3 di 3
    Desoldering Pump
    $3.99
    • Using a soldering iron and desoldering pump, desolder the power adapter port from the board.
    • For more information, see this guide on desoldering
Conclusione
Rachel Shaw
Membro da: 10/06/16
553 Reputazione
5 Guide realizzate
Cal Poly, Team 10-7, Livingston Fall 2016 Membro di Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Membri
12 Guide realizzate
1Commento della guida
What are the specifications of the power port if we would like to replace it?
Chad Altobelli - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 791
