Salta al contenuto principale
Curtain Rod Bracket Replacement
Cosa ti serve
  1. Curtain Rod Bracket Replacement, Bracket: passo 1, immagine 1 di 2 Curtain Rod Bracket Replacement, Bracket: passo 1, immagine 2 di 2
    • If the bracket is still partially attached, use a screwdriver to remove the remaining screw(s), then remove the bracket from the wall completely.
  2. Curtain Rod Bracket Replacement: passo 2, immagine 1 di 2 Curtain Rod Bracket Replacement: passo 2, immagine 2 di 2
    • Observe the hole of the screw(s) that was ripped out of the wall.
    • Determine whether the plastic anchor will fit in the current size of the hole.
    • If the hole is smaller than the anchor, continue to Step 3. If the hole is bigger, complete this guide on patching a hole in dry wall.
  3. Curtain Rod Bracket Replacement: passo 3, immagine 1 di 2 Curtain Rod Bracket Replacement: passo 3, immagine 2 di 2
    • Use a ¼ inch drill bit to drill the hole(s) that the anchor will be placed into. Drill into the wall and continue drilling as you pull out of the wall.
    • Avoid placing hands near the drill bit while in use. If you have medium to long-length hair, tie your hair back to avoid possible injury.
  4. Curtain Rod Bracket Replacement: passo 4, immagine 1 di 3 Curtain Rod Bracket Replacement: passo 4, immagine 2 di 3 Curtain Rod Bracket Replacement: passo 4, immagine 3 di 3
    • Hammer the hollow wall anchor(s) into the hole until flush with the drywall.
  5. Curtain Rod Bracket Replacement: passo 5, immagine 1 di 1
    • Paint the wall anchor and any surrounding area that has been damaged so that it matches the wall.
  6. Curtain Rod Bracket Replacement: passo 6, immagine 1 di 2 Curtain Rod Bracket Replacement: passo 6, immagine 2 di 2
    • Screw the bracket into the anchor(s) with a screwdriver. The bracket will be secured to the wall.
  7. Curtain Rod Bracket Replacement: passo 7, immagine 1 di 2 Curtain Rod Bracket Replacement: passo 7, immagine 2 di 2
    • Touch up with paint if necessary.
  8. Curtain Rod Bracket Replacement: passo 8, immagine 1 di 2 Curtain Rod Bracket Replacement: passo 8, immagine 2 di 2
    • Rehang your curtain rod and curtains by placing the rod onto the bracket.
Conclusione
Enjoy your renewed privacy!
Ashtyn Drake
Membro da: 10/14/22
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 919
