Salta al contenuto principale
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement
Cosa ti serve
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
    • Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: passo 2, immagine 1 di 1
    • Remove the black plastic covering from the motor base.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: passo 3, immagine 1 di 1
    • Locate the connections between the power cord and the brown and white wires. Cut off these connections.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: passo 4, immagine 1 di 1
    • Strip the plastic coating off the edge of the brown and white wires using a wire stripper.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: passo 5, immagine 1 di 1
    • Create a connection between the brown and white wires and the wires of the new power cord by soldering them together.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: passo 6, immagine 1 di 1
    • Fit the wires back into the motor base and place the new power cord in the slot.
Conclusione
By the end of this guide< you will have successfully replaced the power cord to your device.
Reagan Burns
Membro da: 04/02/15
119 Reputazione
1 Guida realizzata
Cal Poly, Team 24-1, Lancaster Spring 2015 Membro di Cal Poly, Team 24-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G1
2 Membri
1 Guida realizzata
4 Commenti
I can't get a replacement cord from cuisinart. Where can I buy one the same?
Elizabeth - Replica
I need one also. drshtender1@gmail.com
Feivel Garnick -
Where can you buy the replacement cord?
ruby48lp - Replica
There's not an exact replacement from Cuisinart, but a two prong replacement will work. I found one "Lamp Cord Set - Black - PLT 56-1854-50 | 1000Bulbs.com" https://www.1000bulbs.com/product/137344... that would work.
Riley Carns - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,629
