Salta al contenuto principale
CrystalView NB4-35788 Auxiliary Speakers Replacement
Cosa ti serve
  1. CrystalView NB4-35788 Auxiliary Speakers Replacement, Auxiliary Speakers: passo 1, immagine 1 di 1
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Auxiliary Speakers Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Auxiliary Speakers Replacement: passo 3, immagine 1 di 1
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Auxiliary Speakers Replacement: passo 4, immagine 1 di 1
    • Two speakers can be found on the device, one in the lower-right corner and one in the lower left-corner.
  5. CrystalView NB4-35788 Auxiliary Speakers Replacement: passo 5, immagine 1 di 1
    • Gently pull up on the speaker to remove it. Repeat this for the other speaker.
  6. CrystalView NB4-35788 Auxiliary Speakers Replacement: passo 6, immagine 1 di 2 CrystalView NB4-35788 Auxiliary Speakers Replacement: passo 6, immagine 2 di 2
    • De-solder the red and black wires to disconnect the old speaker.
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 151
