Salta al contenuto principale
Creative Nomad Jukebox Zen Auxiliary Jack Input placement
Cosa ti serve
  1. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: passo 1, immagine 1 di 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: passo 1, immagine 2 di 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: passo 1, immagine 3 di 3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: passo 2, immagine 1 di 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: passo 2, immagine 2 di 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Screen Cover: passo 3, immagine 1 di 1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Auxiliary Port: passo 4, immagine 1 di 1
  5. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: passo 5, immagine 1 di 1
    • Using the plastic opening tool, gently pry up the other side of the auxiliary jack motherboard.
  6. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: passo 6, immagine 1 di 1
    • Using the plastic pulling tool, pull the plastic housing of the device out of the way in order to wiggle the the auxiliary jack motherboard free.
Conclusione
Bradley McHugh
Membro da: 03/10/17
101 Reputazione
1 Guida realizzata
IUPUI, Team S4-G5, Baechle Spring 2017 Membro di IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 763
