Introduzione
Replacing the RGB lights in the earcups is a technical process that includes disassembly and soldering. This guide walks you through each of the steps to replace the lights in the righthand earcup. For this guide, you will need a soldering kit and a screw driver kit.
Cosa ti serve
Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
There is a small circuit board near the bottom of the muff.
Using a Phillips #0 screwdriver, unscrew the single screw holding the circuit board in place.
Altre 2 persone hanno completato questa guida.
