Salta al contenuto principale
Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement
Cosa ti serve
  1. Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement, Tactile Switch (Scroll Wheel): passo 1, immagine 1 di 2 Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement, Tactile Switch (Scroll Wheel): passo 1, immagine 2 di 2
    • Flip your mouse over so the bottom is facing upwards.
    • Make sure the mouse is disconnected from any ports before tearing it down.
  2. Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 2, immagine 1 di 1
    • There are 2 screws in the base of the M65 elite, either side of the lowest weight screw. Use a long Phillips PH00 to remove these, as they will make removing the inside cover easier
  3. Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 3, immagine 1 di 3 Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 3, immagine 2 di 3 Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 3, immagine 3 di 3
    • Pry in between the aluminum and plastic parts of the lower part of the mouse chassis using a spudger.
    • Work around the left and right click areas with the spudger to further loosen and remove the mouse shell.
    • You may need to use a little force to remove the shell, but not much.
  4. Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 4, immagine 1 di 1
    • Pry in between the aluminum and plastic parts of the upper section of the second mouse chassis using a spudger.
    • Carefully make your way around the chassis with the spudger.
    • Very little force is needed to remove this piece, as long as the 2 underside phillips screws have been removed.
    • Potential for device damage. Do not pull the chassis from the mouse; these parts are connected by sensitive ribbon cables.
  5. Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 5, immagine 1 di 2 Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 5, immagine 2 di 2
    • Remove the three 2 mm screws attached to the PCB using a Phillips screwdriver.
  6. Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove the ribbon cable by lifting up the black section with tweezers or needlenose pliers. The cable will slide right out. Remember the inside side of the cable is all white and the outer side should have blue text on it.
    • Now you can work on the half that has all the components.
  7. Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 7, immagine 1 di 2 Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 7, immagine 2 di 2
    • Carefully pull out the small PCB attached to the side buttons.
    • Remove the main PCB.
  8. Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 8, immagine 1 di 1
    • Spray WD-40/Permatex dielectric grease on the switch/button to lubricate and remove oxidation.
    • Press the tactile switch multiple times after spraying.
  9. Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 9, immagine 1 di 2 Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 9, immagine 2 di 2
    • If your tactile switch is not being replaced, Steps 8 and 9 are optional.
    • Desolder the faulty tactile switch.
    • For soldering help, check out the guide on soldering/desoldering connections.
    • Remove the faulty switch when loosened.
    • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury. Eye protection (safety glasses, goggles, face shields, etc.) must be worn when soldering. Usage of a soldering clamp is highly recommended as soldering irons can reach temperatures of 200°- 480°C.
  10. Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 10, immagine 1 di 2 Corsair M65 RGB ELITE Mouse Tactile Switch (Scroll Wheel) Replacement: passo 10, immagine 2 di 2
    • Solder the new tactile switch.
    • Make sure to heat the solder on to the copper.
    • Clean the solder tip with a brass sponge/normal sponge if necessary.
    • When you're finished, make sure to turn off the iron and allow it to cool off on a soldering iron stand.
Conclusione
Ahmed Amin
Membro da: 10/20/20
253 Reputazione
1 Guida realizzata
7Commenti sulla guida
do not spray WD40 on electronic switches… clean them with alcohol
Cyrus Nagisa - Replica Condividi
Please do not follow step 3 or you’ll break the cover. You don’t have to pry that plastic cover off. Just undo the two screws at the bottom and it easily comes off.
Rafa Shih - Replica Condividi
Also, if your left click feels mushy or has a lot of pre-travel where you can’t spam your clicks, just tighten those two screws at the bottom and that should solve those issues.
I can confirm that opening the mouse , cleaning up the omron micro switch(I am pretty confident those are high quality switch) , lubricating the micro switch , reclosing the mouse and tighten the srews fixed it for me. Theres no problem spraying a small amout of wd on a micro switch in the end its a mechanical micro device. Also do not follow step 1 and 2 . Simply unscrew the two philips screw under the mouse and it open very easely
Molson Dry - Replica Condividi
I have 6 of these mice and none of them have ever worked (since day one). In fact, up till reading this article, I believed this mouse just simply didn't support this feature.
George D. Marsack - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 177
Tutti i Tempi: 15,159
