Salta al contenuto principale
Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement
Cosa ti serve
  1. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Back Panel: passo 1, immagine 1 di 1
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 2, immagine 1 di 2 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 2, immagine 2 di 2
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 3, immagine 1 di 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 3, immagine 2 di 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 3, immagine 3 di 3
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: passo 4, immagine 1 di 2 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: passo 4, immagine 2 di 2
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 5, immagine 1 di 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 5, immagine 2 di 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 5, immagine 3 di 3
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
  6. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Hot/Cold Button: passo 6, immagine 1 di 1
    • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
    • Hold the electrical switches so that the wires are facing upwards.
  7. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: passo 7, immagine 1 di 1
    • Focus on the middle of the three buttons.
    • Desolder the button at the circled locations.
    • To reattach the new button, resolder at the same points. Be sure the wires connect to the correct locations.
Conclusione
Altre 2 persone hanno completato questa guida.
Timothy Lo
Membro da: 04/22/14
1.172 Reputazione
7 Guide realizzate
Cal Poly, Team 10-58, Amido Spring 2014 Membro di Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Membri
14 Guide realizzate
2Commenti sulla guida
so where do you buy parts???
akatser1 - Replica
That's not a capacitor, that's an ion generator like this one https://www.goldmine-elec-products.com/p...
Shannon Carey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 32
Tutti i Tempi: 4,920
