Salta al contenuto principale
Computer King Muffin Kinder 7 Logic Board Replacement
Cosa ti serve
  1. Computer King Muffin Kinder 7 Logic Board Replacement, Logic Board: passo 1, immagine 1 di 2 Computer King Muffin Kinder 7 Logic Board Replacement, Logic Board: passo 1, immagine 2 di 2
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Logic Board Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Logic Board Replacement: passo 3, immagine 1 di 2 Computer King Muffin Kinder 7 Logic Board Replacement: passo 3, immagine 2 di 2
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Logic Board Replacement: passo 4, immagine 1 di 1
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Logic Board Replacement: passo 5, immagine 1 di 3 Computer King Muffin Kinder 7 Logic Board Replacement: passo 5, immagine 2 di 3 Computer King Muffin Kinder 7 Logic Board Replacement: passo 5, immagine 3 di 3
    • Unsolder the 11 red, back, and grey wires connected to the logic board.
    • Tips on how to solder can be found here.
  6. Computer King Muffin Kinder 7 Logic Board Replacement: passo 6, immagine 1 di 3 Computer King Muffin Kinder 7 Logic Board Replacement: passo 6, immagine 2 di 3 Computer King Muffin Kinder 7 Logic Board Replacement: passo 6, immagine 3 di 3
    • Use the flat end of the spudger to lift the black panels covering the three ribbon cables connected to the logic board.
  7. Computer King Muffin Kinder 7 Logic Board Replacement: passo 7, immagine 1 di 1
    • Pull the three ribbon cables out so that they are no longer connected to the logic board.
Conclusione
Katherine
Membro da: 01/22/15
439 Reputazione
3 Guide realizzate
UWT Liner: Group 2 Membro di UWT Liner: Group 2
Community
4 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 387
