Salta al contenuto principale
Comfort Zone CZ6C Switch Replacement
Cosa ti serve
  1. Comfort Zone CZ6C Switch Replacement, Switch: passo 1, immagine 1 di 3 Comfort Zone CZ6C Switch Replacement, Switch: passo 1, immagine 2 di 3 Comfort Zone CZ6C Switch Replacement, Switch: passo 1, immagine 3 di 3
    • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
    • Before replacing your switch, learn how to solder using the How To Solder and Desolder Connections Guide.
    • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
  2. Comfort Zone CZ6C Switch Replacement: passo 2, immagine 1 di 2 Comfort Zone CZ6C Switch Replacement: passo 2, immagine 2 di 2
    • Remove the plastic cover on the switch by pulling it apart from the the back panel.
  3. Comfort Zone CZ6C Switch Replacement: passo 3, immagine 1 di 1
    • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
    • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
    • Disconnect the gray power wire from the switch by desoldering the connection.
  4. Comfort Zone CZ6C Switch Replacement: passo 4, immagine 1 di 2 Comfort Zone CZ6C Switch Replacement: passo 4, immagine 2 di 2
    • Cut the green and yellow wire as close to the switch connection as possible.
  5. Comfort Zone CZ6C Switch Replacement: passo 5, immagine 1 di 3 Comfort Zone CZ6C Switch Replacement: passo 5, immagine 2 di 3 Comfort Zone CZ6C Switch Replacement: passo 5, immagine 3 di 3
    • Strip the green and yellow wire about two centimeters from where it was just cut.
  6. Comfort Zone CZ6C Switch Replacement: passo 6, immagine 1 di 3 Comfort Zone CZ6C Switch Replacement: passo 6, immagine 2 di 3 Comfort Zone CZ6C Switch Replacement: passo 6, immagine 3 di 3
    • Unscrew the switch from the back panel and remove it.
  7. Comfort Zone CZ6C Switch Replacement: passo 7, immagine 1 di 3 Comfort Zone CZ6C Switch Replacement: passo 7, immagine 2 di 3 Comfort Zone CZ6C Switch Replacement: passo 7, immagine 3 di 3
    • After replacing the switch, resolder the gray power cord, the green wire, and the yellow wire.
Conclusione
James Abundis
Membro da: 04/08/15
169 Reputazione
1 Guida realizzata
Cal Poly, Team 17-5, Forte Spring 2015 Membro di Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 Membri
5 Guide realizzate
Un commento
I need a replacement switch for a Comfort Zone CZ40 heater. Can you help?
Michael Drasic - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,399
