Salta al contenuto principale
ColecoVision Power Switch Replacement
Cosa ti serve
  1. ColecoVision Power Switch Replacement, Power Switch: passo 1, immagine 1 di 1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Power Switch Replacement: passo 2, immagine 1 di 2 ColecoVision Power Switch Replacement: passo 2, immagine 2 di 2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Power Switch Replacement: passo 3, immagine 1 di 1
    • Remove the two 15 mm screws holding the casing in place using the Phillips #1 screwdriver.
  4. ColecoVision Power Switch Replacement: passo 4, immagine 1 di 2 ColecoVision Power Switch Replacement: passo 4, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the two 15mm screws on the motherboard.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Power Switch Replacement: passo 5, immagine 1 di 1
    • Flip the motherboard over.
    • Using a soldering iron, carefully desolder the power switch from the motherboard.
    • Refer to this soldering technique guide for reference.
  6. ColecoVision Power Switch Replacement: passo 6, immagine 1 di 1
    • Wait for power switch to cool down.
    • Turn the motherboard over upright.
    • Carefully lift up the power switch to completely remove it from the motherboard.
Conclusione
Bobby
Membro da: 10/17/18
380 Reputazione
2 Guide realizzate
UW Tacoma, Team S1-G2, Rose Fall 2018 Membro di UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 2,132
