Salta al contenuto principale
ColecoVision Controller Port Replacement
Cosa ti serve
  1. ColecoVision Controller Port Replacement, Controller Port: passo 1, immagine 1 di 1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Controller Port Replacement: passo 2, immagine 1 di 2 ColecoVision Controller Port Replacement: passo 2, immagine 2 di 2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Controller Port Replacement: passo 3, immagine 1 di 2 ColecoVision Controller Port Replacement: passo 3, immagine 2 di 2
    • Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
    • Remove the casing and put it to the side.
  4. ColecoVision Controller Port Replacement: passo 4, immagine 1 di 2 ColecoVision Controller Port Replacement: passo 4, immagine 2 di 2
    • Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Controller Port Replacement: passo 5, immagine 1 di 3 ColecoVision Controller Port Replacement: passo 5, immagine 2 di 3 ColecoVision Controller Port Replacement: passo 5, immagine 3 di 3
    • Flip the motherboard over and locate the two controller ports.
    • Using a soldering iron, desolder the controller ports.
    • Refer to this soldering technique guide for reference.
    • After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
Conclusione
Bobby
Membro da: 10/17/18
380 Reputazione
2 Guide realizzate
UW Tacoma, Team S1-G2, Rose Fall 2018 Membro di UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 22
Tutti i Tempi: 837
