Salta al contenuto principale
Coby KYROS MID7125 Screen Replacement
Cosa ti serve
  1. Coby KYROS MID7125 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
  2. Coby KYROS MID7125 Screen Replacement: passo 2, immagine 1 di 3 Coby KYROS MID7125 Screen Replacement: passo 2, immagine 2 di 3 Coby KYROS MID7125 Screen Replacement: passo 2, immagine 3 di 3
    • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger.
    • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
    • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
    • Desolder fifth ribbon cable with soldering station.
    • If soldering is new for you, then follow this useful guide on soldering and desoldering connections.
  3. Coby KYROS MID7125 Screen Replacement: passo 3, immagine 1 di 3 Coby KYROS MID7125 Screen Replacement: passo 3, immagine 2 di 3 Coby KYROS MID7125 Screen Replacement: passo 3, immagine 3 di 3
    • Desolder 2 speaker wires
    • Desolder Battery
    • Desolder antenna wire
    • Disconnect all wires you desoldered
  4. Coby KYROS MID7125 Screen Replacement: passo 4, immagine 1 di 1
    • Desolder the microphone wire
    • Disconnect the wires you just desoldered.
  5. Coby KYROS MID7125 Screen Replacement: passo 5, immagine 1 di 1
    • Remove 4 screws that connect the motherboard to the device.
  6. Coby KYROS MID7125 Screen Replacement: passo 6, immagine 1 di 1
    • Take off motherboard by lifting off right hand side and pulling sideways.
  7. Coby KYROS MID7125 Screen Replacement: passo 7, immagine 1 di 2 Coby KYROS MID7125 Screen Replacement: passo 7, immagine 2 di 2
    • Remove 4 screws on corners of the digitizer and lift off.
  8. Coby KYROS MID7125 Screen Replacement: passo 8, immagine 1 di 2 Coby KYROS MID7125 Screen Replacement: passo 8, immagine 2 di 2
    • Now that the digitizer is disconnected from the screen you can replace the screen.
    • Place the screen face down in front of you facing downward and apply pressure with your thumbs around the outside of the glass to remove the screen.
    • Next, replace with your new screen and follow steps in reverse order to reassemble.
Conclusione
Nicole Connelly
Membro da: 10/20/16
1 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 5-2, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 336
