Introduzione
Follow this guide to replace the lower drive chain on a 2018 Classen Sod Cutter model HSC18AHD.
Cosa ti serve
Passo 1 Safety precautions
Attenzione: i passaggi 1-4 provengono da una guida contrassegnata come in corso.
Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
Slide the cutter blade out from under the machine to remove it.
Passo 8 Remove the chain guard
Attenzione: i passaggi 8-10 provengono da una guida contrassegnata come in corso.
Use a 1/2 inch socket to remove the 130 mm-long bolt securing the chain guard.
Use a marker to mark the locations for each bearing before disassembly.
