Salta al contenuto principale
Clarke Floor Buffer 01278A 2016 Power Cord Replacement
Cosa ti serve
  1. Clarke Floor Buffer 01278A 2016 Power Cord Replacement, Remove the Handle Enclosure: passo 1, immagine 1 di 1
    • Before you begin, make sure the floor buffer is turned off and unplugged.
    • Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
  2. Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 2, immagine 1 di 3 Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 2, immagine 2 di 3 Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 2, immagine 3 di 3
    • The rear half of the enclosure is bolted to the handle tube, so you'll only need to remove the front half.
    • Pull the front half of the enclosure straight away from the rear half to separate the enclosure.
    • If the interlock assembly comes out with the front half of the enclosure, detach it and place it back into the rear half.
    • Remove the front half of the handle enclosure.
  3. Clarke Floor Buffer 01278A 2016 Power Cord Replacement, Remove the Interlock Assembly: passo 3, immagine 1 di 3 Clarke Floor Buffer 01278A 2016 Power Cord Replacement, Remove the Interlock Assembly: passo 3, immagine 2 di 3 Clarke Floor Buffer 01278A 2016 Power Cord Replacement, Remove the Interlock Assembly: passo 3, immagine 3 di 3
    • Pull the wires connected to the interlock assembly straight out of their connectors.
    • Keep track of where each wire connects to on the interlock assembly.
  4. Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 4, immagine 1 di 1
    • After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
  5. Clarke Floor Buffer 01278A 2016 Power Cord Replacement, Remove the Power Cord: passo 5, immagine 1 di 1
    • Use a 3/16" hex key or driver bit to remove the 13.8 mm-long screw securing the power cord's green ground wire to the handle enclosure.
    • This screw is accompanied with a lock washer. Make sure to retain it for re-assembly.
  6. Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 6, immagine 1 di 1
    • Use a 7/8" wrench to loosen the coupling securing the power cord to the handle enclosure.
  7. Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 7, immagine 1 di 2 Clarke Floor Buffer 01278A 2016 Power Cord Replacement: passo 7, immagine 2 di 2
    • Pull the power cord straight down and out of the handle enclosure.
    • To avoid damaging the wires, remove the power cord slowly and make sure the wires don't snag on anything as they come out.
Conclusione
Altre 5 persone hanno completato questa guida.
Craig Lloyd
Membro da: 02/10/16
38.707 Reputazione
82 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 66
Tutti i Tempi: 3,344
