Salta al contenuto principale
Chromo Noria Battery Replacement
Cosa ti serve
  1. Chromo Noria Battery Replacement, Back Panel: passo 1, immagine 1 di 3 Chromo Noria Battery Replacement, Back Panel: passo 1, immagine 2 di 3 Chromo Noria Battery Replacement, Back Panel: passo 1, immagine 3 di 3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Battery Replacement: passo 2, immagine 1 di 1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Battery Replacement, Battery: passo 3, immagine 1 di 3 Chromo Noria Battery Replacement, Battery: passo 3, immagine 2 di 3 Chromo Noria Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
  4. Chromo Noria Battery Replacement: passo 4, immagine 1 di 3 Chromo Noria Battery Replacement: passo 4, immagine 2 di 3 Chromo Noria Battery Replacement: passo 4, immagine 3 di 3
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
  5. Chromo Noria Battery Replacement: passo 5, immagine 1 di 1
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
Conclusione
Kevin Nguyen
Membro da: 10/31/16
159 Reputazione
1 Guida realizzata
Baylor, Team 5-6, Williams Fall 2016 Membro di Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 506
