Cosa ti serve
Passo 1 Cassida Counterfeit Detector Disassembly
Attenzione: i passaggi 1-6 provengono da una guida contrassegnata come in corso.
Remove the rubber legs.
Get your solder iron and set it to 660 deg Fahrenheit.
Solid core wire is easier to use than standard.
Desolder the contact point for the wire by pressing the hot iron to the contact point until the solder flows and the cable can be pulled from the board.
For more detailed help with soldering and desoldering, check out this handy guide for tips and best practices.
