Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
For this disassembly we will need a phillips screwdriver 1.5 and a pair of tweezers. Prepare a little container for screws: they are tiny!
Parti
Nessuna parte specificata.
  1. This super strong Casio watch is more docile than waht you might think. We don't need to twist off the front's screws. It doesn't bite, so let's turn it around
    • This super strong Casio watch is more docile than waht you might think.
    • We don't need to twist off the front's screws.
    • It doesn't bite, so let's turn it around
  2. With the phillips screwdriver take off these four screws Lift up an extremity of the watchstrap and remove the base. You can use a flat screwdriver to help you
    • With the phillips screwdriver take off these four screws
    • Lift up an extremity of the watchstrap and remove the base.
    • You can use a flat screwdriver to help you
    • With the tweezers lift the white plastic cover
    • Be careful to not damage the golden springs!! So take your time
  3. With the tip of the tweezers you have to unclip the clips into the red rectangles. Just insert the tweezer's tip in the center of the bracket and pull toward the center of the watch Just insert the tweezer's tip in the center of the bracket and pull toward the center of the watch
    • With the tip of the tweezers you have to unclip the clips into the red rectangles.
    • Just insert the tweezer's tip in the center of the bracket and pull toward the center of the watch
  4. Extract the battery leveraging with the tweezers. Keep attention to the golden springs again! The clip, holding down the central batteries, completely removes
    • Extract the battery leveraging with the tweezers.
    • Keep attention to the golden springs again!
    • The clip, holding down the central batteries, completely removes
Conclusione
Altre 3 persone hanno completato questa guida.
Acn0w
Membro da: 20/09/2018
3.911 Reputazione
1 Guida realizzata
cannot see the “Golden Springs”. Where are they? Thank you
mike.malapascua - Replica
would be nice to have a description if the battery type, to buy before disassembling.. Thank you
mike
Sorry if I wasn’t imprecise, the “Golden Springs” is located above the first battery on the left. More precisely in second step of the guide I marked it.
Coin shaped Batteries are Sony SR927W:
* 1.55 Volt
* 60 mAh
Acn0w -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 119
Tutti i Tempi: 2,293
