Salta al contenuto principale
Casio LK-170 Button Replacement
Cosa ti serve
  1. Casio LK-170 Button Replacement, Button: passo 1, immagine 1 di 2 Casio LK-170 Button Replacement, Button: passo 1, immagine 2 di 2
    • Using a JIS-1 screwdriver, remove the seven 11 mm screws located on the back of the keyboard.
  2. Casio LK-170 Button Replacement: passo 2, immagine 1 di 1
    • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
    • Flip the middle panel up so that the component board can be seen.
  3. Casio LK-170 Button Replacement: passo 3, immagine 1 di 3 Casio LK-170 Button Replacement: passo 3, immagine 2 di 3 Casio LK-170 Button Replacement: passo 3, immagine 3 di 3
    • In this step, you will be removing a total of 26 screws.
    • First, you will use a PH-1 bit to remove the 17 8mm screws circled in red.
    • Next, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wires, circled in orange.
    • Then, using a JIS-1 bit, we will remove three 7mm screws from the circuit board, circled in yellow.
    • After removing the circuit board, the last three screws are revealed, circled in green. You will use the PH-1 bit to remove these last screws.
  4. Casio LK-170 Button Replacement: passo 4, immagine 1 di 1
    • Once all the screws have been removed, lift the panel and place it face down on the keys.
    • The panel is connected to the keyboard, so do not try to remove it.
  5. Casio LK-170 Button Replacement: passo 5, immagine 1 di 2 Casio LK-170 Button Replacement: passo 5, immagine 2 di 2
    • Under the panel are the buttons. Remove them by pulling from any corner with your fingers.
    • Remove all the buttons that need to be replaced.
Conclusione
Eileen Tran
Membro da: 01/24/17
108 Reputazione
1 Guida realizzata
Cal Poly, Team 13-2, Banghart Winter 2017 Membro di Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 678
