Salta al contenuto principale
Canon Selphy CP910 Printer Body Replacement
Cosa ti serve
  1. Canon Selphy CP910 Printer Body Replacement, Disassembling Canon Selphy CP910 Body: passo 1, immagine 1 di 2 Canon Selphy CP910 Printer Body Replacement, Disassembling Canon Selphy CP910 Body: passo 1, immagine 2 di 2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Printer Body Replacement: passo 2, immagine 1 di 3 Canon Selphy CP910 Printer Body Replacement: passo 2, immagine 2 di 3 Canon Selphy CP910 Printer Body Replacement: passo 2, immagine 3 di 3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Printer Body Replacement: passo 3, immagine 1 di 3 Canon Selphy CP910 Printer Body Replacement: passo 3, immagine 2 di 3 Canon Selphy CP910 Printer Body Replacement: passo 3, immagine 3 di 3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Printer Body Replacement: passo 4, immagine 1 di 3 Canon Selphy CP910 Printer Body Replacement: passo 4, immagine 2 di 3 Canon Selphy CP910 Printer Body Replacement: passo 4, immagine 3 di 3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Printer Body Replacement, Printer Body: passo 5, immagine 1 di 2 Canon Selphy CP910 Printer Body Replacement, Printer Body: passo 5, immagine 2 di 2
    • Use the PH1 screw driver to remove the three screws on the motherboard.
  6. Canon Selphy CP910 Printer Body Replacement: passo 6, immagine 1 di 2 Canon Selphy CP910 Printer Body Replacement: passo 6, immagine 2 di 2
    • Remove the printer.
    • This will prevent the printer from falling out during repair.
  7. Canon Selphy CP910 Printer Body Replacement: passo 7, immagine 1 di 3 Canon Selphy CP910 Printer Body Replacement: passo 7, immagine 2 di 3 Canon Selphy CP910 Printer Body Replacement: passo 7, immagine 3 di 3
    • Remove the output connections.
    • Be careful! Do not pull too hard because the wires might rip.
    • Output connections are located on the corners of the motherboard.
  8. Canon Selphy CP910 Printer Body Replacement: passo 8, immagine 1 di 2 Canon Selphy CP910 Printer Body Replacement: passo 8, immagine 2 di 2
    • The motherboard is attached to three more ribbon wires.
    • Detach these wires.
    • Be careful not to pull too hard.
  9. Canon Selphy CP910 Printer Body Replacement: passo 9, immagine 1 di 2 Canon Selphy CP910 Printer Body Replacement: passo 9, immagine 2 di 2
    • Separate the motherboard from the main hard drive.
  10. Canon Selphy CP910 Printer Body Replacement: passo 10, immagine 1 di 3 Canon Selphy CP910 Printer Body Replacement: passo 10, immagine 2 di 3 Canon Selphy CP910 Printer Body Replacement: passo 10, immagine 3 di 3
    • Remove the main hard drive from the printer body.
  11. Canon Selphy CP910 Printer Body Replacement: passo 11, immagine 1 di 2 Canon Selphy CP910 Printer Body Replacement: passo 11, immagine 2 di 2
    • Gently remove the fan from the body.
    • The fan is glued to the case. When you install it in the new body, use hot glue to secure it in place.
  12. Canon Selphy CP910 Printer Body Replacement: passo 12, immagine 1 di 2 Canon Selphy CP910 Printer Body Replacement: passo 12, immagine 2 di 2
    • The empty case will look like this once all the parts are removed.
Conclusione
Altre 2 persone hanno completato questa guida.
UW Tacoma, Team 1-6, Rose Winter 2016 Membro di UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 53
Tutti i Tempi: 4,359
