Salta al contenuto principale
Canon Selphy CP910 LCD Screen Replacement
Cosa ti serve
  1. Canon Selphy CP910 LCD Screen Replacement, Disassembling Canon Selphy CP910 Body: passo 1, immagine 1 di 2 Canon Selphy CP910 LCD Screen Replacement, Disassembling Canon Selphy CP910 Body: passo 1, immagine 2 di 2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 LCD Screen Replacement: passo 2, immagine 1 di 3 Canon Selphy CP910 LCD Screen Replacement: passo 2, immagine 2 di 3 Canon Selphy CP910 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 LCD Screen Replacement: passo 3, immagine 1 di 3 Canon Selphy CP910 LCD Screen Replacement: passo 3, immagine 2 di 3 Canon Selphy CP910 LCD Screen Replacement: passo 3, immagine 3 di 3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 LCD Screen Replacement: passo 4, immagine 1 di 3 Canon Selphy CP910 LCD Screen Replacement: passo 4, immagine 2 di 3 Canon Selphy CP910 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 LCD Screen Replacement, LCD Screen: passo 5, immagine 1 di 3 Canon Selphy CP910 LCD Screen Replacement, LCD Screen: passo 5, immagine 2 di 3 Canon Selphy CP910 LCD Screen Replacement, LCD Screen: passo 5, immagine 3 di 3
    • Once you detach the top, turn the device around.
    • Use the PH0 screw bit to remove the five [size] screws.
  6. Canon Selphy CP910 LCD Screen Replacement: passo 6, immagine 1 di 3 Canon Selphy CP910 LCD Screen Replacement: passo 6, immagine 2 di 3 Canon Selphy CP910 LCD Screen Replacement: passo 6, immagine 3 di 3
    • Push out the LCD screen from the main case.
    • The screen should slide out freely.
  7. Canon Selphy CP910 LCD Screen Replacement: passo 7, immagine 1 di 3 Canon Selphy CP910 LCD Screen Replacement: passo 7, immagine 2 di 3 Canon Selphy CP910 LCD Screen Replacement: passo 7, immagine 3 di 3
    • Pull out the rod connecting the LCD screen to the frame.
    • Insert the new screen.
Conclusione
UW Tacoma, Team 1-6, Rose Winter 2016 Membro di UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,201
