Salta al contenuto principale
Canon Selphy CP910 Buttons Replacement
Cosa ti serve
  1. Canon Selphy CP910 Buttons Replacement, Body: passo 1, immagine 1 di 2 Canon Selphy CP910 Buttons Replacement, Body: passo 1, immagine 2 di 2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Buttons Replacement: passo 2, immagine 1 di 3 Canon Selphy CP910 Buttons Replacement: passo 2, immagine 2 di 3 Canon Selphy CP910 Buttons Replacement: passo 2, immagine 3 di 3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Buttons Replacement: passo 3, immagine 1 di 3 Canon Selphy CP910 Buttons Replacement: passo 3, immagine 2 di 3 Canon Selphy CP910 Buttons Replacement: passo 3, immagine 3 di 3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Buttons Replacement: passo 4, immagine 1 di 3 Canon Selphy CP910 Buttons Replacement: passo 4, immagine 2 di 3 Canon Selphy CP910 Buttons Replacement: passo 4, immagine 3 di 3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Buttons Replacement, Buttons: passo 5, immagine 1 di 2 Canon Selphy CP910 Buttons Replacement, Buttons: passo 5, immagine 2 di 2
    • Turn the top panel over so the inside faces toward you.
  6. Canon Selphy CP910 Buttons Replacement: passo 6, immagine 1 di 3 Canon Selphy CP910 Buttons Replacement: passo 6, immagine 2 di 3 Canon Selphy CP910 Buttons Replacement: passo 6, immagine 3 di 3
    • Use the PH0 screw bit to remove the five 10 mm screws located above the circuit board.
  7. Canon Selphy CP910 Buttons Replacement: passo 7, immagine 1 di 2 Canon Selphy CP910 Buttons Replacement: passo 7, immagine 2 di 2
    • Carefully remove the frame attached to the screen.
  8. Canon Selphy CP910 Buttons Replacement: passo 8, immagine 1 di 3 Canon Selphy CP910 Buttons Replacement: passo 8, immagine 2 di 3 Canon Selphy CP910 Buttons Replacement: passo 8, immagine 3 di 3
    • Take out the circuit board.
    • Once you take out the circuit board, you should be left with just the case.
  9. Canon Selphy CP910 Buttons Replacement: passo 9, immagine 1 di 2 Canon Selphy CP910 Buttons Replacement: passo 9, immagine 2 di 2
    • There is a clear plastic ā€œLā€ shaped piece that acts as the power light for the printer. The piece is not attached to the printer so take care not to lose it.
    • Remove the button framework and replace it with new one.
Conclusione
UW Tacoma, Team 1-6, Rose Winter 2016 Membro di UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,046
