Salta al contenuto principale
Canon Powershot A610 Speaker Replacement
Cosa ti serve
  1. Canon Powershot A610 Speaker Replacement, Speaker: passo 1, immagine 1 di 3 Canon Powershot A610 Speaker Replacement, Speaker: passo 1, immagine 2 di 3 Canon Powershot A610 Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Remove the three screws attaching the side panel using a Phillips #00 screwdriver.
    • Remove the side paneling from the camera.
    • Remove the two remaining screws attached to the frame of the camera.
  2. Canon Powershot A610 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the two screws on the bottom panel of the camera.
  3. Canon Powershot A610 Speaker Replacement: passo 3, immagine 1 di 1
    • Open the battery cover.
    • Remove the four screws inside.
    • One screw is located on the top side of the bottom cover. The remaining three screws are located at the bottom of the battery compartment.
    • Close the battery cover.
  4. Canon Powershot A610 Speaker Replacement: passo 4, immagine 1 di 2 Canon Powershot A610 Speaker Replacement: passo 4, immagine 2 di 2
    • Open the "DIGITAL AV OUT" door on the camera.
    • Remove the three screws.
    • Remove the door from the camera.
  5. Canon Powershot A610 Speaker Replacement: passo 5, immagine 1 di 1
    • Gripping the sides of the top cover, gently pull apart the top cover from the camera.
    • The top cover does not completely detach.
  6. Canon Powershot A610 Speaker Replacement: passo 6, immagine 1 di 2 Canon Powershot A610 Speaker Replacement: passo 6, immagine 2 di 2
    • Gently pull apart the front cover from the camera.
    • This may require some force. Be careful not to break the plastic.
  7. Canon Powershot A610 Speaker Replacement: passo 7, immagine 1 di 2 Canon Powershot A610 Speaker Replacement: passo 7, immagine 2 di 2
    • Using an opening tool, push the black attachment away from the white connection piece to detach the connector ribbon.
  8. Canon Powershot A610 Speaker Replacement: passo 8, immagine 1 di 1
    • Remove the 3 mm screw holding the metal frame.
  9. Canon Powershot A610 Speaker Replacement: passo 9, immagine 1 di 2 Canon Powershot A610 Speaker Replacement: passo 9, immagine 2 di 2
    • Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
    • Use a bit of force as the speaker is glued into the top casing.
    • There is a soft fabric speaker cover separating the speaker from the casing. Make sure not to remove it from its position in the housing.
  10. Canon Powershot A610 Speaker Replacement: passo 10, immagine 1 di 1
    • Desolder the speaker at the two solder points and reattach the new speaker.
Conclusione
Cal Poly, Team 11-26, Maness Winter 2011 Membro di Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,926
