Introduzione
Disassemble the back cover in order to open the camera and access the inside components.
Strumenti
Parti
Nessuna parte richiesta.
Turn the camera to the side that has the screen. Unnscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
Turn the camera with the lens facing down.
Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
Keep making pressure and slowly slide the opening tool through all the gap.
There is one point when the cover will disassemble completely.
Altre 2 persone hanno completato questa guida.
Un commento
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
