Salta al contenuto principale
Introduzione
This replacement guide will show you how to access the flash capacitor of the Canon Powershot SD780 IS.
Be extremely careful in dealing with the capacitor as it can store a large electrical charge for a long period of time. The safest way to handle a capacitor is by discharging it. You can make a capacitor discharge tool by following the Constructing a Capacitor Discharge Tool guide.
Strumenti opzionali
Ricambi
Nessuna parte specificata.
    • Begin by making sure the camera is turned off and the battery has been removed to avoid any shock injuries.
  1. Having removed the battery, you can begin removing the outermost screws on the camera to allow for case replacement. There are 5 screws in total. This will require a Philips head # 00 screwdriver. Keep track of where each screw came from in order to avoid complications during the reassemble process.
    • Having removed the battery, you can begin removing the outermost screws on the camera to allow for case replacement. There are 5 screws in total. This will require a Philips head # 00 screwdriver.
    • Keep track of where each screw came from in order to avoid complications during the reassemble process.
    • The screws highlighted by the red circles in the second image (on the left side in the first image) are 2.0 mm long.
  2. Remove the front panel of the camera case to expose the top left copper strip, and gently pull the strip upward to disconnect from camera.
    • Remove the front panel of the camera case to expose the top left copper strip, and gently pull the strip upward to disconnect from camera.
  3. Remove the screw on the far left hand side of the camera.
    • Remove the screw on the far left hand side of the camera.
  4. Now that you have removed all of the screws, carefully pull the case apart at the seem. The case will detach from the camera in two pieces.
    • Now that you have removed all of the screws, carefully pull the case apart at the seem. The case will detach from the camera in two pieces.
  5. Locate the image stabilizer on the top right of the camera and pry the internal battery away from the camera. Having done this, the internal battery can be removed easily.
    • Locate the image stabilizer on the top right of the camera and pry the internal battery away from the camera. Having done this, the internal battery can be removed easily.
  6. You have now exposed the internal battery, and you may proceed to exchange the old internal battery for a new one.
    • You have now exposed the internal battery, and you may proceed to exchange the old internal battery for a new one.
Conclusione
Arlene Ale
Membro da: 13/03/2014
455 Reputazione
4 Guide realizzate
Un commento
what is the number for the replacement battery?
peterprosser - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 666
