Salta al contenuto principale
Canon PowerShot SD1400 IS User Interface Panel Replacement
Cosa ti serve
  1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: passo 1, immagine 1 di 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: passo 1, immagine 2 di 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: passo 1, immagine 3 di 3
    • Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
  2. Canon PowerShot SD1400 IS User Interface Panel Replacement: passo 2, immagine 1 di 1
    • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS User Interface Panel Replacement: passo 3, immagine 1 di 1
    • Remove the front face panel of the camera by hand using firm pressure.
    • If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
  4. Canon PowerShot SD1400 IS User Interface Panel Replacement: passo 4, immagine 1 di 1
    • Remove the rear panel of the camera by hand using firm pressure.
  5. Canon PowerShot SD1400 IS User Interface Panel Replacement: passo 5, immagine 1 di 1
    • Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
    • Replace the user interface panel by setting it in position.
Conclusione
Altre 2 persone hanno completato questa guida.
Braxton Beal
Membro da: 01/30/18
696 Reputazione
3 Guide realizzate
Baylor, Team S1-G3, Johnson Spring 2018 Membro di Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 274
