Introduzione
USB Port can be damaged from force exertion on the pins which can prevent it to connect to an external device. This guide will show the steps to replace the USB port in the device.
  1. Remove the four 2mm Phillips #00 screws on both sides of the camera. Remove the four 2mm Phillips #00 screws on both sides of the camera. Remove the four 2mm Phillips #00 screws on both sides of the camera.
    • Remove the four 2mm Phillips #00 screws on both sides of the camera.
  2. Remove the single 4mm Phillips #00 screw from the bottom.
    • Remove the single 4mm Phillips #00 screw from the bottom.
  3. Remove the front face panel off of the camera.
    • Remove the front face panel off of the camera.
  4. Remove the rear panel of the camera.
    • Remove the rear panel of the camera.
    • The user interface panel, side and bottom panel of the camera may fall down by itself while you are taking the rear panel of the camera.
  5. Remove the 3mm Phillips #000 screw from the top of the camera.
    • Remove the 3mm Phillips #000 screw from the top of the camera.
  6. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  7. Pry the golden ribbon cable from the motherboard with a plastic opening tool.
    • Pry the golden ribbon cable from the motherboard with a plastic opening tool.
    • A screw will be visible underneath the golden ribbon after prying it.
  8. Remove the 3mm Phillips #000 screw from the motherboard.
    • Remove the 3mm Phillips #000 screw from the motherboard.
  9. Use a plastic opening tool to flip up the retaining flap on the  ribbon cable ZIF socket.
    • Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
  10. Unplug the small chip from the face of the camera using a pair of tweezers. Unplug the small chip from the face of the camera using a pair of tweezers.
    • Unplug the small chip from the face of the camera using a pair of tweezers.
  11. Remove the 3mm Phillips #000 screw from the rear face of the camera.
    • Remove the 3mm Phillips #000 screw from the rear face of the camera.
  12. Remove the top panel from the camera.
    • Remove the top panel from the camera.
  13. Pry the golden ribbon cable attached to the USB port using a plastic opening tool.
    • Pry the golden ribbon cable attached to the USB port using a plastic opening tool.
  14. Remove the 3mm Phillips #000 screw located at the top right of the USB port.
    • Remove the 3mm Phillips #000 screw located at the top right of the USB port.
  15. Remove the USB port. Remove the USB port.
    • Remove the USB port.
Conclusione
Faris Rezwan
Membro da: 21/05/2018
433 Reputazione
2 Guide realizzate
IUPUI, Team S1-G2, Harley Spring 2018 Membro di IUPUI, Team S1-G2, Harley Spring 2018
IUPUI-HARLEY-S18S1G2
7 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 118
