Salta al contenuto principale
Canon PowerShot S410 Battery Replacement
  1. Canon PowerShot S410 Battery Replacement, Battery: passo 1, immagine 1 di 2 Canon PowerShot S410 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Canon PowerShot S410 Battery Replacement: passo 2, immagine 1 di 1
    • Pull the orange lever and the battery will spring out slightly.
  3. Canon PowerShot S410 Battery Replacement: passo 3, immagine 1 di 2 Canon PowerShot S410 Battery Replacement: passo 3, immagine 2 di 2
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
Conclusione
After a new battery has been inserted, close the swinging door and you're done. Take your e-waste to an R2 or e-Stewards certified recycler.
Randy Lormand
Membro da: 01/23/11
349 Reputazione
3 Guide realizzate
Cal Poly, Team 11-27, Maness Winter 2011 Membro di Cal Poly, Team 11-27, Maness Winter 2011
CPSU-MANESS-W11S11G27
4 Membri
7 Guide realizzate
Un commento
One piece battery
Aasim Ansari - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,769
