Salta al contenuto principale
Canon EOS 300 Bottom Panel Replacement
Cosa ti serve
  1. Canon EOS 300 Bottom Panel Replacement, Batteries: passo 1, immagine 1 di 3 Canon EOS 300 Bottom Panel Replacement, Batteries: passo 1, immagine 2 di 3 Canon EOS 300 Bottom Panel Replacement, Batteries: passo 1, immagine 3 di 3
    • Open up the battery door.
  2. Canon EOS 300 Bottom Panel Replacement: passo 2, immagine 1 di 2 Canon EOS 300 Bottom Panel Replacement: passo 2, immagine 2 di 2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Bottom Panel Replacement, Side Panel with Lever: passo 3, immagine 1 di 2 Canon EOS 300 Bottom Panel Replacement, Side Panel with Lever: passo 3, immagine 2 di 2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Bottom Panel Replacement: passo 4, immagine 1 di 2 Canon EOS 300 Bottom Panel Replacement: passo 4, immagine 2 di 2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Bottom Panel Replacement: passo 5, immagine 1 di 2 Canon EOS 300 Bottom Panel Replacement: passo 5, immagine 2 di 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Bottom Panel Replacement, Front Panel: passo 6, immagine 1 di 2 Canon EOS 300 Bottom Panel Replacement, Front Panel: passo 6, immagine 2 di 2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Bottom Panel Replacement: passo 7, immagine 1 di 2 Canon EOS 300 Bottom Panel Replacement: passo 7, immagine 2 di 2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Bottom Panel Replacement: passo 8, immagine 1 di 2 Canon EOS 300 Bottom Panel Replacement: passo 8, immagine 2 di 2
    • Remove the front panel by pulling away from the side with the lever.
    There is another loose part here that can come off on the side of the latch. It's also off in the picture. When reassembling, make sure to reconnect it to the spring as well, otherwise the back panel opening mechanism will not work correctly.
    Ruben - Replica
  9. Canon EOS 300 Bottom Panel Replacement, Bottom Panel: passo 9, immagine 1 di 2 Canon EOS 300 Bottom Panel Replacement, Bottom Panel: passo 9, immagine 2 di 2
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
    When reassembling, make sure that the hole on the bottom panel for the rightmost 4.8mm Phillips #1 screw (orange) goes underneath the hole still attached to the camera.
    Ruben - Replica
  10. Canon EOS 300 Bottom Panel Replacement: passo 10, immagine 1 di 3 Canon EOS 300 Bottom Panel Replacement: passo 10, immagine 2 di 3 Canon EOS 300 Bottom Panel Replacement: passo 10, immagine 3 di 3
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
Conclusione
Tammy Kong
Membro da: 01/23/14
771 Reputazione
6 Guide realizzate
Cal Poly, Team 6-20, Maness Winter 2014 Membro di Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Membri
32 Guide realizzate
Un commento
muy buena la explicacion de como desmontar la maquina. Te has gadano los 30 puntos
Ricardo Alonso Gurrea - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 731
