Salta al contenuto principale
Calculator is Stuck While Graphing
  1. Calculator is Stuck While Graphing, Calculator is Stuck While Graphing: passo 1, immagine 1 di 1
    • To cancel the graphing process, press the "ON" button.
  2. Calculator is Stuck While Graphing: passo 2, immagine 1 di 3 Calculator is Stuck While Graphing: passo 2, immagine 2 di 3 Calculator is Stuck While Graphing: passo 2, immagine 3 di 3
    • Go to "Zoom." Navigate to and highlight "ZoomFit" then press "Enter." Doing so will automatically set your graphing window to the most appropriate dimensions.
  3. Calculator is Stuck While Graphing: passo 3, immagine 1 di 1
    • If you are graphing complex equations, multiple equations, or a combination of the two, it may take anywhere from 1 minute to 5 minutes to graph.
    • The bar on the top right corner indicates the calculator is graphing.
  4. Calculator is Stuck While Graphing: passo 4, immagine 1 di 2 Calculator is Stuck While Graphing: passo 4, immagine 2 di 2
    • If you feel that your graph is taking too long, you can change the step resolution to a bigger number. To do so, press "Window" and change "Xres" to a value between 1 and 8. A bigger Xres value will graph more quickly.
Conclusione
It is always a good idea to make sure your graph will display a good window.
John Baek
Membro da: 09/27/12
31 Reputazione
4 Guide realizzate
Cal Poly, Team 7-52, Forte Fall 2012 Membro di Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,952
