Salta al contenuto principale
CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement
Cosa ti serve
  1. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Power Cord: passo 1, immagine 1 di 1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: passo 2, immagine 1 di 1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: passo 3, immagine 1 di 2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: passo 3, immagine 2 di 2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: passo 4, immagine 1 di 2 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: passo 4, immagine 2 di 2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: passo 5, immagine 1 di 3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: passo 5, immagine 2 di 3 CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement: passo 5, immagine 3 di 3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Temperature Control Switch Replacement, Temperature Control Switch: passo 6, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the screws on both sides of the temperature control switch.
    • Pop out the control switch.
Conclusione
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Membro di UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 240
