Salta al contenuto principale
Braven BRV-X Front Speaker Panel Replacement
Cosa ti serve
  1. Braven BRV-X Front Speaker Panel Replacement, Front Speaker Panel: passo 1, immagine 1 di 1
    • Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
  2. Braven BRV-X Front Speaker Panel Replacement: passo 2, immagine 1 di 1
    • Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
  3. Braven BRV-X Front Speaker Panel Replacement: passo 3, immagine 1 di 1
    • Gently remove the outer shell.
  4. Braven BRV-X Front Speaker Panel Replacement: passo 4, immagine 1 di 2 Braven BRV-X Front Speaker Panel Replacement: passo 4, immagine 2 di 2
    • Cut adhesive tape on both sides.
  5. Braven BRV-X Front Speaker Panel Replacement: passo 5, immagine 1 di 2 Braven BRV-X Front Speaker Panel Replacement: passo 5, immagine 2 di 2
    • Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
  6. Braven BRV-X Front Speaker Panel Replacement: passo 6, immagine 1 di 3 Braven BRV-X Front Speaker Panel Replacement: passo 6, immagine 2 di 3 Braven BRV-X Front Speaker Panel Replacement: passo 6, immagine 3 di 3
    • Pry open the glued inner shell using a spudger around all sides of the shell.
    • Don't use too much pressure as that could cause damage to the plastic.
  7. Braven BRV-X Front Speaker Panel Replacement: passo 7, immagine 1 di 2 Braven BRV-X Front Speaker Panel Replacement: passo 7, immagine 2 di 2
    • Remove ten 0.7 cm screws in the front plate using the 1.5 mm Hex screwdriver.
  8. Braven BRV-X Front Speaker Panel Replacement: passo 8, immagine 1 di 2 Braven BRV-X Front Speaker Panel Replacement: passo 8, immagine 2 di 2
    • Use a spudger to open the front speaker plate.
  9. Braven BRV-X Front Speaker Panel Replacement: passo 9, immagine 1 di 1
    • Remove three 1.0 cm screws from the battery unit.
    • It is recommended (but not required) to remove the battery.
  10. Braven BRV-X Front Speaker Panel Replacement: passo 10, immagine 1 di 2 Braven BRV-X Front Speaker Panel Replacement: passo 10, immagine 2 di 2
    • Disconnect the ribbon cable attached the main board.
  11. Braven BRV-X Front Speaker Panel Replacement: passo 11, immagine 1 di 3 Braven BRV-X Front Speaker Panel Replacement: passo 11, immagine 2 di 3 Braven BRV-X Front Speaker Panel Replacement: passo 11, immagine 3 di 3
    • Pry open the second plate holding in the speaker using a spudger around all sides.
    • It is recommended to use a spudger to remove the heavily glued areas between the plates before prying.
  12. Braven BRV-X Front Speaker Panel Replacement: passo 12, immagine 1 di 3 Braven BRV-X Front Speaker Panel Replacement: passo 12, immagine 2 di 3 Braven BRV-X Front Speaker Panel Replacement: passo 12, immagine 3 di 3
    • Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
    • Leave enough length on the wire to work with it afterwards.
    • Cut the 22 gauge wire attached in the corner.
    • Solder the new speaker plate during reassembly.
    • To properly solder and desolder connections, visit the How to Solder and Desolder Connections guide.
Conclusione
Trey Peterson
Membro da: 04/01/19
301 Reputazione
2 Guide realizzate
IUPUI, Team S1-G5, Harley Spring 2019 Membro di IUPUI, Team S1-G5, Harley Spring 2019
IUPUI-HARLEY-S19S1G5
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 268
