Salta al contenuto principale
Bose QuietComfort 25 Motherboard Replacement
Cosa ti serve
  1. Bose QuietComfort 25 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Begin repair by removing the ear cushion.
    • The cushion is held on by a few small plastic clips. Pry carefully with plastic opening tool or fingernails.
  2. Bose QuietComfort 25 Motherboard Replacement: passo 2, immagine 1 di 1
    • Next, remove the soft lining behind the cushion. This is held on with adhesive and is easily removed by hand.
  3. Bose QuietComfort 25 Motherboard Replacement: passo 3, immagine 1 di 3 Bose QuietComfort 25 Motherboard Replacement: passo 3, immagine 2 di 3 Bose QuietComfort 25 Motherboard Replacement: passo 3, immagine 3 di 3
    • Once the soft lining is removed from behind the ear cushion, two screws will be exposed.
    • Carefully remove the two 5 mm screws with a precision screwdriver (PH00) and put aside.
  4. Bose QuietComfort 25 Motherboard Replacement: passo 4, immagine 1 di 1
    • Flip the earphones back over and carefully pry around the outside cover of the earpiece.
    • Try a plastic opening tool before moving on to harder metal tools.
    • This cover will come loose with moderate pressure.
  5. Bose QuietComfort 25 Motherboard Replacement: passo 5, immagine 1 di 3 Bose QuietComfort 25 Motherboard Replacement: passo 5, immagine 2 di 3 Bose QuietComfort 25 Motherboard Replacement: passo 5, immagine 3 di 3
    • There are 3 screws holding the motherboard to the earpiece.
    • Remove these screws to make the next step easier.
  6. Bose QuietComfort 25 Motherboard Replacement: passo 6, immagine 1 di 1
    • Once the motherboard is exposed, all of the soldered connection will need to be removed.
    • Be careful of this step and take note of the position of each wire.
    • This should only be attempted by someone with experience soldering small components, as irreparable damage may be result from improper methods. For help with this step see this guide on Come saldare e dissaldare componenti elettrici
  7. Bose QuietComfort 25 Motherboard Replacement: passo 7, immagine 1 di 1
    • After removing all the soldered joints, the motherboard can be removed by hand.
    • The connections will all need to be re-soldered into their respective locations.
Conclusione
Altre 6 persone hanno completato questa guida.
Samuel Coss
Membro da: 03/26/18
339 Reputazione
1 Guida realizzata
IUPUI, Team S2-G3, Harley Spring 2018 Membro di IUPUI, Team S2-G3, Harley Spring 2018
IUPUI-HARLEY-S18S2G3
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 83
Tutti i Tempi: 11,261
