Salta al contenuto principale
BlackBerry PlayBook USB Port Replacement
Cosa ti serve
  1. BlackBerry PlayBook USB Port Replacement, Remove Back Panel: passo 1, immagine 1 di 2 BlackBerry PlayBook USB Port Replacement, Remove Back Panel: passo 1, immagine 2 di 2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook USB Port Replacement, Motherboard: passo 2, immagine 1 di 2 BlackBerry PlayBook USB Port Replacement, Motherboard: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the battery connector using either your fingers or a pair of tweezers.
  3. BlackBerry PlayBook USB Port Replacement: passo 3, immagine 1 di 2 BlackBerry PlayBook USB Port Replacement: passo 3, immagine 2 di 2
    • Unscrew two 1.17x2.9mm Phillips screws from the white connector port.
    • Lift the battery connector away from the motherboard using a spudger.
  4. BlackBerry PlayBook USB Port Replacement: passo 4, immagine 1 di 2 BlackBerry PlayBook USB Port Replacement: passo 4, immagine 2 di 2
  5. BlackBerry PlayBook USB Port Replacement: passo 5, immagine 1 di 2 BlackBerry PlayBook USB Port Replacement: passo 5, immagine 2 di 2
  6. BlackBerry PlayBook USB Port Replacement: passo 6, immagine 1 di 3 BlackBerry PlayBook USB Port Replacement: passo 6, immagine 2 di 3 BlackBerry PlayBook USB Port Replacement: passo 6, immagine 3 di 3
    • Remove the clipped ZIF data connector coming from underneath the motherboard.
    • Lift up the black plastic clip with a spudger.
    • Pull the connector out gently using tweezers.
    • Be careful to ensure that the black plastic clip has been lifted away from the connector ribbon before pulling on the connector. The clip should be loose and easy to wiggle. Removing the connector before it is unclipped can cause damage.
  7. BlackBerry PlayBook USB Port Replacement, Unscrew Motherboard: passo 7, immagine 1 di 1
    • Remove the following five screws from the motherboard.
    • Three 1.5x2.5mm Phillips screws
    • Two 1.55x2.38mm Phillips screws
  8. BlackBerry PlayBook USB Port Replacement, Remove Wire Leads: passo 8, immagine 1 di 1
  9. BlackBerry PlayBook USB Port Replacement, Remove Motherboard: passo 9, immagine 1 di 2 BlackBerry PlayBook USB Port Replacement, Remove Motherboard: passo 9, immagine 2 di 2
    • Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
  10. BlackBerry PlayBook USB Port Replacement, Desolder the USB port: passo 10, immagine 1 di 1
    • Use your soldering skills to detach the USB port from the motherboard at the following two solder joints.
Conclusione
Altre 14 persone hanno completato questa guida.
Nathan
Membro da: 10/12/14
673 Reputazione
4 Guide realizzate
Cal Poly, Team 14-27, Maness Fall 2014 Membro di Cal Poly, Team 14-27, Maness Fall 2014
CPSU-MANESS-F14S14G27
4 Membri
12 Guide realizzate
6 Commenti
excelent step by step guide not taking peoples knowledge for granted good stuff rgards pete smith.
callum Smith - Replica
Fantastically easy to follow step by step instructions with diagrams that are superbly explained - afterall I am but a 'mere woman's!! Thankyou, I love this site. Definitely *****
Justine Franklin - Replica
J'ai changer les batteries et j'ai une image plein de ligne,qu'est-ce qu'il se passe ?
Sylvain - Replica
I was defeated but the USB port which has proof impossible to unsolder. I give up.. let’s just hold I have not damaged the board
Stephen Missah - Replica
i had tge same issue, cant desolder? what to do now, its in my hand right now.
catmando1962 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 34
Tutti i Tempi: 12,473
