Salta al contenuto principale
BlackBerry PlayBook Motherboard Replacement
Cosa ti serve
  1. BlackBerry PlayBook Motherboard Replacement, Remove Back Panel: passo 1, immagine 1 di 2 BlackBerry PlayBook Motherboard Replacement, Remove Back Panel: passo 1, immagine 2 di 2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Motherboard Replacement, Motherboard: passo 2, immagine 1 di 2 BlackBerry PlayBook Motherboard Replacement, Motherboard: passo 2, immagine 2 di 2
    • Remove the battery connector using either your fingers or a pair of tweezers.
  3. BlackBerry PlayBook Motherboard Replacement: passo 3, immagine 1 di 2 BlackBerry PlayBook Motherboard Replacement: passo 3, immagine 2 di 2
    • Unscrew two 1.17x2.9mm Phillips screws from the white connector port.
    • Lift the battery connector away from the motherboard using a spudger.
  4. BlackBerry PlayBook Motherboard Replacement: passo 4, immagine 1 di 2 BlackBerry PlayBook Motherboard Replacement: passo 4, immagine 2 di 2
  5. BlackBerry PlayBook Motherboard Replacement: passo 5, immagine 1 di 2 BlackBerry PlayBook Motherboard Replacement: passo 5, immagine 2 di 2
  6. BlackBerry PlayBook Motherboard Replacement: passo 6, immagine 1 di 3 BlackBerry PlayBook Motherboard Replacement: passo 6, immagine 2 di 3 BlackBerry PlayBook Motherboard Replacement: passo 6, immagine 3 di 3
    • Remove the clipped ZIF data connector coming from underneath the motherboard.
    • Lift up the black plastic clip with a spudger.
    • Pull the connector out gently using tweezers.
    • Be careful to ensure that the black plastic clip has been lifted away from the connector ribbon before pulling on the connector. The clip should be loose and easy to wiggle. Removing the connector before it is unclipped can cause damage.
  7. BlackBerry PlayBook Motherboard Replacement, Unscrew Motherboard: passo 7, immagine 1 di 1
    • Remove the following five screws from the motherboard.
    • Three 1.5x2.5mm Phillips screws
    • Two 1.55x2.38mm Phillips screws
  8. BlackBerry PlayBook Motherboard Replacement, Remove Wire Leads: passo 8, immagine 1 di 1
  9. BlackBerry PlayBook Motherboard Replacement, Remove Motherboard: passo 9, immagine 1 di 2 BlackBerry PlayBook Motherboard Replacement, Remove Motherboard: passo 9, immagine 2 di 2
    • Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
Conclusione
Altre 6 persone hanno completato questa guida.
Nathan
Membro da: 10/12/14
661 Reputazione
4 Guide realizzate
Cal Poly, Team 14-27, Maness Fall 2014 Membro di Cal Poly, Team 14-27, Maness Fall 2014
CPSU-MANESS-F14S14G27
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 32
Tutti i Tempi: 3,299
