Salta al contenuto principale
BlackBerry KeyONE partial Disassembly
Cosa ti serve
  1. BlackBerry KeyONE partial Disassembly, Remove top cover: passo 1, immagine 1 di 1
    • Carefully remove the top plastic cover. It is held in place by adhesive.
  2. BlackBerry KeyONE partial Disassembly, Remove top frame: passo 2, immagine 1 di 2 BlackBerry KeyONE partial Disassembly, Remove top frame: passo 2, immagine 2 di 2
    • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
  3. BlackBerry KeyONE partial Disassembly, Remove back cover: passo 3, immagine 1 di 1
    • Remove the back cover. It mostly just clips off, but has some adhesive in the lower area.
  4. BlackBerry KeyONE partial Disassembly, Disconnect Battery: passo 4, immagine 1 di 2 BlackBerry KeyONE partial Disassembly, Disconnect Battery: passo 4, immagine 2 di 2
    • Remove the two Philipps #0 screws securing the battery connector and unplug the later.
  5. BlackBerry KeyONE partial Disassembly: passo 5, immagine 1 di 1
    • Remove the 6 Philipps #0 screws securing the lower cover and remove it.
    • Remove the three Philipps #0 screws holding down the bar that secures the two main lego-style plugs and remove it.
  6. BlackBerry KeyONE partial Disassembly, Remove top cover: passo 6, immagine 1 di 1
    • Remove the three Philipps #0 screws securing the upper cover and remove it.
  7. BlackBerry KeyONE partial Disassembly: passo 7, immagine 1 di 1
    • Unplug the remaining ribbon cables
    • Remove the last three Philipps #0 screws securing the Motherbard.
    • Now you should be able to replace most components.
    • The screen is held in place from the front by adhesive (or not, in the earlier versions), its cable slides trough the phone to the PCB - It's the large connector in the middle.
    • The battery is glued to the frame firmly. There are three pultabs located underneath the motherboard.
    • Don't forget to remove the sim-tray if you're removing the motherboard.
Conclusione
Altre 14 persone hanno completato questa guida.
raven
Membro da: 09/02/15
1.080 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 87
Tutti i Tempi: 9,525
