Salta al contenuto principale
Bissell CrossWave Cordless Max 2554A Handle Replacement
Cosa ti serve
  1. Bissell CrossWave Cordless Max 2554A Handle Replacement, Handle: passo 1, immagine 1 di 1
    • Start by facing the vacuum away from you so that you are looking at the back side of the clean water tank.
  2. Bissell CrossWave Cordless Max 2554A Handle Replacement: passo 2, immagine 1 di 3 Bissell CrossWave Cordless Max 2554A Handle Replacement: passo 2, immagine 2 di 3 Bissell CrossWave Cordless Max 2554A Handle Replacement: passo 2, immagine 3 di 3
    • The handle release mechanism is a small hole directly above the clean water tank and below the handle.
    • Using the pointed end of a spudger, press the mechanism to release the handle.
    • You might need to shimmy it a bit, as pressing too hard may prevent the handle from releasing.
  3. Bissell CrossWave Cordless Max 2554A Handle Replacement: passo 3, immagine 1 di 2 Bissell CrossWave Cordless Max 2554A Handle Replacement: passo 3, immagine 2 di 2
    • Remove the handle from the vacuum.
Conclusione
To reassemble your device, reinsert the handle back into the main body of the vacuum, listening for an audible click.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 34
Tutti i Tempi: 172
