Salta al contenuto principale
Bissell CrossWave Cordless Max 2554A Charging Cord Replacement
Cosa ti serve
  1. Bissell CrossWave Cordless Max 2554A Charging Cord Replacement, Charging Cord: passo 1, immagine 1 di 2 Bissell CrossWave Cordless Max 2554A Charging Cord Replacement, Charging Cord: passo 1, immagine 2 di 2
    • Flip the charging base over, so that the support pillar is facing down.
  2. Bissell CrossWave Cordless Max 2554A Charging Cord Replacement: passo 2, immagine 1 di 2 Bissell CrossWave Cordless Max 2554A Charging Cord Replacement: passo 2, immagine 2 di 2
    • Remove the two 11.6 mm Phillips #1 screws deep within the pillar.
  3. Bissell CrossWave Cordless Max 2554A Charging Cord Replacement: passo 3, immagine 1 di 1
    • Remove the plastic piece holding the cord, as well as the charging cord.
    • When replacing the charging cord, ensure that the new unit has the same voltage and current limits, as to not damage the internal battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 65
