Salta al contenuto principale
Beiens Cartoon RC Race Car LED Light Replacement
Cosa ti serve
  1. Beiens Cartoon RC Race Car LED Light Replacement, LED Light: passo 1, immagine 1 di 1
    • Hold the remote control with the backside facing you and, using the Phillips #00 screwdriver, unscrew the six 6.5 mm screws on the back of the controller that hold it together.
  2. Beiens Cartoon RC Race Car LED Light Replacement: passo 2, immagine 1 di 1
    • Open the remote control.
  3. Beiens Cartoon RC Race Car LED Light Replacement: passo 3, immagine 1 di 1
    • Lift the motherboard to separate it from the remote control.
  4. Beiens Cartoon RC Race Car LED Light Replacement: passo 4, immagine 1 di 1
    • To remove the light, use a soldering iron to heat the solder to a liquid and loosen the leads.
    • While the solder is liquid, lightly pull on the LED to remove it from the motherboard.
    • The soldering iron will get very hot while it's in use. Be sure to place it on top of a heat protected surface and be careful not to touch the operational end.
Conclusione
Amber Ashley
Membro da: 10/01/15
329 Reputazione
4 Guide realizzate
USF Tampa, Team 1-6, Leahy Fall 2015 Membro di USF Tampa, Team 1-6, Leahy Fall 2015
USFT-LEAHY-F15S1G6
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 295
